AAAAArrrrgggghhhhh - headlight removal
I HATE NISSANS
why do they make the headlight so goddamned hard to remove.
My old poopra headlamp could be removed in 3 mins.
I have just spent the best part of nearly an hour and half in the rain trying to get the poxy thing out.
Basically - headlight has a hole in it and I have a replacement.
so I thought - I'd fit my HID's at same time.
A, cant work out exactly how easy it is to seperate glass - done a search and found a hairdrier blown on glass sealant may help.
B, cant work out how the F**K to undo the 2 bolts at the back of the left headlamp to remove it.
Ive removed the maf and y-pipe, removed the front dummy fog light, so can now undo the front 2 bolts.
the back bolt seems to be irectly under the hard pipe inlet? - Do I have to remove that.
As for the last bolt - WTF - How the hell do you get to that - I can sort of feel the bolt by going in through the dummy light enclosure but cant qork out whether I need a spanner or socket?
Please tell me theres an easy way to do all of this. .
If I do manage to remove the headlamp assembly - is it really worth splitting the glass to clean it for HID's??
AFAIK there is a small lens in front of the light - is it worth cleaning that instead?
