Is a blown fuse the cause?
Took my ZX on a track day. Good fun!
On the way home, found the radio was dead and the air con had switched off. Radio would not turn on but air con worked fine when readjusted – until I switch the ignition off, then all goes back to zero.
Question 1: Are these two things related or is it just coincidence?
Question 2: If it is a fuse, is it in the main box and, to save me hunting, can any one please described which one it is? If not a fuse, what's causing this?
Ta!
Btw, the site does not seem to like my Mac's Safari browser tonight. had to swap to Firefox... never had this before...
Does sound like a fuse check the fuses down by the throttle pedal
never had any look with safari - have to reload all the time!! You should try FireFox... seems to be compatible with almost anything!
Rich
