Is that all?
or should the PS pump move more, cos i cant get it to go any further!
Yes mate thats it,hardly any movement available,leave lose,cut of old belt,put on new one by sliping/prising over pully(small one first)then use flat screwdriver or simlar to get on bigger pully,then push PS back what amount you can,then tighten up.
Tony :)
thanks tony, iv got UR pulley set going on and i cant get the belt on with both the PS pulley and crank pulley fitted, it seems way out. on the belt it says Nissan A172M-59SSA-VW 4PK880
iv stripped out my AC and the belt for that is slightly longer, can i just use that???
I see,yes this normal in most cases fitting aftermarket pullys,some suppliers can allso supply the belts for specific cars with underdrive sets,was it UK comp.Ryan should be able to sort you maybe as i know he can get drive belts.
Tony :)
Tony :)
sorted it tony thanks, the ac belt was too long so i just went to a motor factor and bought the next size up from what i had for the PS, used a 4PK900
