Oil pressure...
Hi,
I'm currently using Castrol RS 10-60 but my oil pressure is up and down. It sits at a nice 60ish then can drop down to around 20ish (i think its usually when its hot). I'd like it to be a bit more constant as I'm having a boost upgrade. Any ideas lads??
Cheers,
Bart..
The sender unit is probably knackered, common problem bud, fit an aftermarket guage or a new sender.
Sounds standard mate, dont think you have anything to worry about. If you've got the monet then by an aftermarket system.
Thanks lads, I didn't want to change oil as my Z seems like the RS 10-60. Any idea how much a new sender is?
Are they hard to change?
