oil catch tank
anyone got an oil catch tank fitted? where on earth are you supposed to put it?
maybe where the aiv's were but then it would be a bugger to get to for emptying
Excuse the ignorance, but what is an oil catch tank?
I bleieve its some sort of breather for the pipes, catches misted oil?
Mine will be fitted as soon as I start to run crazy boost,I will post pics as soon as its fitted mate;)
If you're going to do it, best to run a vacuum pump on it to actually pull a vacuum on the crank case. Does tend to smell pretty bad too unless you run the vent to somewhere under the car.
