replacing the water?
ive got one of those ally rad pipes, the lower ones?
gona drain the water and re fill
i take it you refill via the rad?
best way to get rid of air locks??
thanks
:dance:
Just remove the radiator cap and then get underneath and you should find a plastic pipe, about 3 inches long which has a "tap" on it, open it up and drain her out. On the UK rad it's on the bottom left as you look at the front of the car. PS Don't refill with water, use proper coolant otherwise prolonged use of water causes corrosion of the rad.
There is also a reservoir on the right of the rad with a fill level indicator.
I took my rad off the other day for a reason I wont go into and it only took about a hour to remove check replace and refill and i'm no mechanic. Got to do it again this week when I get my new rad pipes from Smithy and replace with proper coolant.
im handy with a spanner but with the Zed its like
WTH
where do u begin lol
It's a tight little space much like that nun I once had......ooh sorry getting carried away. LOL
