protoj ·
Just a word of warning as this happens very often on the TTNET. Guys come online selling goods and take money usual fraud.
Be sure you know who you are buying from regarding companys and people.
these people could be on our forums
[This message has been edited by 300z (edited 28-12-2001).]
