Really annoying game!!
  • Replies 83
  • Views 2.5k
you got everything now??
select blanket and click about item, then when it zooms onto that item
click lighter then click on blanket to tear it ;)
ok lock done beer cold and back to shrine i must be missing summat wiv the pills and paper
Look in tub of pills there is a peice of paper with a load of chines shit written on but i am still non the wiser, also examine red blanket you tear it and get a dominoes puzzle. I am still stuck.
put cd in its case.
then select pubic paper hehe and use lighter on it a few times,
to reveal sumit ;)
the green thing is a dice and the bits of paper go on it but dont know what order
what you will find on paper are dice numbers in the same pattern as the chinese numbers from the pill bottle, the 6 pieces of paper match some of the numbers on that sheet. what you have to do is look where the number 1 is on the paper you burnt, see
which chinese number it matches up with in the pattern, then drag the corrisponding piece of the 6 chinese bits of paper onto the flat cross shaped dice and place in the 1 position and repeat for the rest of the 6 sides, then when done correctly, you will have a SOUL CUBE!!!! it will turn into a cube
sorry, very hard to explain
ok go get beer from fridge, place it, the cd case (wiv cd init) and bundle of sticks on grey cabinet next to the thing thats dings, then select lighter and click on sticks to light one, then hit gong, and you're outta there (unless u do it wrong lol)
And then when you're out i got another one for ya MUHAHAHAHAHAHAHAHAHA
BUT i haven't done this one yet, just found it, so you'll be ON YOUR OWN!!!!!
from which postion??? there's one on the light
Theres also one chinese paper up on the whatever-you-call-it-roof-thinggy (cant find the right word for it) :p
Somethings still missing. Got photo of girl in frame, beer, cd in case, insence burning and a chinese box.
Quite hard for someone to tell you what you're missing if you dont post what you've done/have :rolleyes: :)
Aaahhh Boll ocks to this i am off to have a beer and a joint. Might try later.
Didnt help I am still stuck and i dont know if i am meant to have the pic of the bloke or the pic of the woman in the frame :smash: :confused: :confused: :confused: :confused: :confused: :confused: :confused:
Come in Bandit i need you.
no pic needed, kinda pointless really,
make sure you've unlocked the skeleton and that the beer is cold
and unless I've forgotten summit, that should be it.....
remember to light the sticks too
Does that chinese box thing stay in you inventry as i can not put it down at the shrine? And i have an empty space to the right of the incence burner opposite side of the sticks.
