Link needed please
I remember seeing a link with an engine bay, the engine bay was numbered with each engine part. If you remember the link please send it on to me....
1. Air Intake Hose
2. Turbo Hose
3. Power Steering Reservoir
4. C.A.S (Crank Angle Sensor)
5. P.T.U (Power Transfer Unit)
6. Windscreen Washer Bottle
7. Engine Coolant Tank
8. Fuse Box
9. 6 Coil Packs
10. Oil Cap
11. Radiator Cap
12. HICAS Solenoid
13. Radiator
14. E.C.U. Water Temperature Sensor
15. Dashboard Water Temperature Sensor
16. Fuel Filter
17. Brake Fluid Reservoir
18. Clutch Fluid Reservoir
19. Brake Servo
20. Air Filter
21. Throttle/Cruise Control Cable
22. TPS (Throttle Position Sensor)
23. Passenger Side Stock Boost Solinoid connector
24. Driver Side Stock Boost Solinoid connector
25. Driver Side O2 sensor Connector
26. Det Sensor Connector
27. Passenger Side O2 sensor Connector
28. Fuel Damper
29. Fuel Pressure Regulator
30. Balance Bar
Thanks again blackmagic
no probs :duffer: :duffer: :duffer:
9pm and im lashed on cider...result :dance: ...WoooooHoooooooooooooo
Good lad!
lol.....
Scibdibley dodab doo da :dance:
:duffer: :duffer: :duffer: :duffer: :duffer: :duffer:
I might have a nice cold can of stela in a mo! MMMmmm
Why not its only gone 9pm...
  • 2 months later...
Courtesy seems to suggest that the fuel damper and fuel pressure regulator are the otherway around, ie 29 is the fuel damper and 28 is the FPR.
Can anyone confirm?
