power loss
just give me car a good caining and when i got to 6000 rpm the car just dies like it is hitting the limiter
i know my tps is knackered or out of adjustment
was wondering if this was causing the prob or is it something else
Wrong timing, over heating, oil leaks, chip settings.
MAS failing, PTU failing,
I would check your timing first.
cheers will do, ive got a maf
just thought i had only just washed my car before i took it out for a spin (could be water on maf)
Probably. That has been known to do it.
If you try all this stuff and you still have a problem, PM me . I've just cured a similar problem that won't even show up on a conzult.
