clocks 300zx
hi i havw a 300zx none turbo jap import on a 92 the speedo is in kph i have removed the whole set of clocks if i put another set in that show mph will they work ok just by reconecting with the mulit plugs i have taken off the old ones and hes asking 275 for the clocks is this a bit steep hope u can help me and will it take off that bell when i go over 105 kph yep1062@hotmail.com
great news where would i get the 30 pound mph converter looked all over the net for one and thank i will work on the bell
Best way in my opinion is to get a set of UK clocks which as Legrath said should set you back about £100 and is a pretty easy job to swap over, if you get some Jspec clocks that have had a different resistor soldered in they will also work or a set of Jspec clocks with the little black box still attached that alters the speedo reading will do it.
i have added u to my messenger hope u dont mind
Or buy the converrter and fit it, I think someone said before that the zcentre sells them, if not I am sure I have seen them on ebay before now.
best bet is UK clocks and a wire removal .........i have had two speedo delimiters
and they have both gone bad ....total cost about 60 quid a throw 120 quid ..i have now got some clocks waiting for me thanks to Mickey B for holding on to them
thanks dont no what u mean by wire removal
