August 5, 200521 yr Hi Everyone, thanks for your help on my last issue! Can any one give me a bit more info on ECU's and what type do I have, the numbers on it are 36 A18-A33 MAZ 0726 Also is there a correct setting for normal running that the adjustment screw should be.. fully anti clock or full clock! please advise Hope u can help? Cheers Doug
August 5, 200521 yr Hi Everyone, thanks for your help on my last issue! Can any one give me a bit more info on ECU's and what type do I have, the numbers on it are 36 A18-A33 MAZ 0726 Also is there a correct setting for normal running that the adjustment screw should be.. fully anti clock or full clock! please advise Hope u can help? Cheers Doug Hi, cant help you on type of ECU, but that adjustment screw is the screw to turn diagnostics mode on for checking error codes. It should be fully anti-clockwise when your not checking for codes. Although Im not sure if it actually makes a difference what you leave it in. details here http://www.ttzd.com/tech/diagnostictech.html
36
A18-A33 MAZ 0726
Hope u can help?
Cheers Doug
