settings for Blitz DSBC-R
Hi all,
Had one of the above installed yesterday by Jeff. I've pulled off the manual at the 'geocities' site and although it explains things quite well I still cant quite get my head around what settings to start off with. What settings have any of you guys put in? I know I need to play with it to get the best out of it but what would be the 'safe' limits to start off with?
Cheers,
Dave.
...actually there seems to be a problem with it. the 'current' boost pressure stays at zero, even though both my gauges read boost. and the controller seems to be limiting me to 10-11 psi. ive done a quick check on the pipework both into the controller and where it's teed off in the engine bay but they all seem to be ok. :confused:
Quoted by Dave, "actually there seems to be a problem with it"
Maybe that`s why the seller of the boost controller was selling it :(
That is the problem with second hand kit,your never sure until fitted if it actually is working, if you still having problems will take another look for you, see if there is a work around if it is faulty, failing that may have to replace it.
Jeff TT
Ratio's set at 0 , 33 , 47 , 57 gain set 8 - 15 test it and see which gain works best for you. limit 1.1 bar
Jeff TT
:mad: :mad: :mad: i bought that from an ex-member on here.
would it not working mean that the car runs at normal boost then?
damn it thats really pi$$ed me off now!
