Follow up questions on Jeff's detonation thread
- Replies 35
- Views 449
- Created
- Last Reply
- No registered users viewing this page.
Hey guys,
I have tried everything I can think of to cure my detonation problem and nothing has helped. So far I've tried running on Optimax exclusively (well over 2000 miles by now), changed to a JWT chip, changed to NGKxx-11b spark plugs from Courtesy, cleaned every sensor/connector I could get my hands on, even installed a JWT pop-charger and corrected the timing to 15degrees BTDC. Still the same rattling noise between 2k and 3k revs under light load.
Under Jeff's thread Phil_m mentioned clogged up injectors and the lambda sensor. How do you clean the injectors and how do you check that the lambda sensor is functioning properly?
If there is anyone else out there who could run off a list of possible causes of detonation then please clue me in ... I'm getting desparate now.
Thanks for you help guys!
Danny
[This message has been edited by Danny (edited 17-12-2001).]
