TT radiator
Can i fit a TT Radiator in a NA? Apart from the different mounting brackets do i need anything else? Is the pipe work the same?
pipework is not the same either, i think the mounts do fit though
Bottom coolant pipe is the same, top coolant pipe is slightly different, though you could use a 45 deg silicone bend that i often sell to N/A owners. or do a blue peter jobbie on your existing.
smithy
