NZR: IT help please (service packs)
Upgraded computer and many,many problems arrose (still not right).
lots of various crashes and blue screens I think its the ram myself?.
Anyway when reinstalling thought to myself....Do you need to install service packs 1 AND 2 or can you just install 2?
maybe a dumb question,
cheers
What version of Windows is it?
If it's 2000 or XP then just 2 will do it.
The patches for XP are cumulative, i.e. you can install SP2 on a clean install without having to install SP1.
Did you do a fresh installation of Windows when you changed your computer? Or did you use an already existing installation?
Fresh install on new hard drives (SATA)
the problem is ram as I have been running for about an hour now with no crashes I am going to leave 3dmark 03 on later and see if it survives.
I have 2 different sticks of memory (pc 2700 + pc 3200) and I have taken the 2700 out.
I have order 2 x 3200 from dabs just now and will recive tomorrow morning.
Cheers for the input lads now I know where to ask instead of searching through loads of pc forums! :D :rofl:
3Dmark03 is a graphics card tester, 01 is a more intensive system work out ;) Other things to use are Prime95 and superPi on a 64m setting.
Computer seemed to crash with 'internet explorer has crashed, dont sent or send error report bull'
this happened on many other applications.
But everytime I looked a vidoes or graphics (gamewise) it just blue screened.
will download 01 now ;)
Do a search for memtest86 in google .. they do a bootable floppy and cd for testing memory .. also sounds like it might be overheating so make sure the heatsink is seated and use a good quality thermal past suh as articsilver not the useless pads they normally come with.
Mix'n'match RAM is a bad thing. Keep it all the same speed and if possible the same manufacturer.
