knocking noise
got a bad vibration knocking noise thought it was the prop bearing at first but been out for a drive again and when cornering to the left gets worse and when cornering to right completely goes away am I right in thinking n/s/r wheel bearing? had the car jacked up an no play on bearings :confused: :confused:
I've been on the beer but Left hand corners will load the O/S mate check the drivers side. What kinda noise you getting does it vary with speed changes ??
vibration,knocking an when slowing like a grinding noise
Assuming it a drive train noise e.g it stops when the car stops moving but the engine still running ??
just seeing if any 1 else had any advice will add to to messenger 2nite cheers
This may be a stupid suggestion, but it isn't your exhaust banging against something, is it? I was getting an odd vibrating/knocking noice and it turned out that one of my exhausts wasn't fully on to one of the rubber hangers. A quick smack with a hammer and problem solved! :hyper:
