Noisy cam
anyone know what would cause this?
Noticed tonight oil pressure a little low - topped it up but when car is ticking over it sounds like someone is hitting engine with a hammer.
If you look in the oil fill hole and watch the cam go round it seems to be at same speed as that.
I have tried putting more oil in but it hasnt quietened down.
how low was oil level before you topped it up. These cars have small sumps and there is'nt a lot between min and max. Letting them get as low as minumum can cause damage :(
that I dont quiet know - there is no dipstick on this car
I have always just done the 3k mile change.
Never had a prob before
new oil has been in for about 1k.
what damage could have been done?
could it just be a noisy tappet?
Im beginning to doubt now whether noise has always been there. . . . . .
From my experiance.. there could be a number of things...
Tappets... oil pump.. it could be completly unrelated to the oil issue...
but most likely not....
worse case ... dare i say it could have caused piston damnage.. depends on the noise....
cant really say... i would have it looked at quickly if your not sure... could be something simple... but if it sounds like a banging noise... its a worry.
if the cars been sitting for a while i think its normal for it to this, quietens down after a nice long drive. something about hydraulic lifters? one of the techies will confirm
mine has a noisy cam as well it's just the hydraulic lifters wear after a while mine just was like it when i bought the car and has suddenly got worse but mine has done 130,000 miles so a top end rebuild is the answer look in the traders section ryan at z tech is your best bet to get it sorted
thanks for the advice people.
Noise went away this morning after a few seconds.
Oil pressure back at normal now and I took it for a long drive.
relief!!!!!!!!!!!!!!!!!!!!!!!!!!!
:dance:
