Rays alloys
I can get lm gt4 nismo wheels for a real good price,
Since they are build for a Z33 i don't know if they gonna fits my Z32
front 18 x 8.5 offset 25mm
rear 18 x 9.5 offset 30mm
will they fit :confused:
I am pretty sure they will as they Z33 has some quite large brakes.
Have a look on Rays site. They list the sizes and have tell you which ones fit the 300ZX and 350Z
I'm not so sure they'll fit as the offset is quite a bit off. For a Z32 the offset is 35-42. Your best bet will be to see if you can trial-fit them ... it's the only way to be sure.
Dan
Dan
But as the width of the wheel changed the off set changes too.
WheelOffsetCalculator
Stock
front 16x7.5 45 mm offset
rear 16x8.5 35 mm offset.
Gt4
front 18x8.5 25mm offset
rear 18x9.5 30mm offset
Front
Inner Clearance:7mm MORE (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 33mm (position of the outside edge of the wheel)
Rear
Inner Clearance:8mm less (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 18mm (position of the outside edge of the wheel)
Rear will fit no prob.
For the front ill put 33mm spacer on stock wheels and give it a try ;)
You're right Stuart - I stand corrected :)
All the best,
Danny
