my zed will give me terrets
i no ,someone had this as an avatar,,,, but,, on way home from z tech on m25 cruising at 75mph,, at low revs, because i just had new turbos fitted etc etc, feeling great, got her back after her sitting on drive for 2 months, when a loud grinding noise was heard i looked around thought is that me when the steering went very hard and lost all drive, no engine, all lights on dash , got her to hard shoulder, ,, no turn over just one click like a sound of dead battery ,, but battery is fine,, pacth of oil under her too:shock: :confused: :shock: :cry: :cry: :cry: ,,
really did swear a lot a hell of a lot., just spent 2.7 k. on her and she does this,, if had been married i would of hired a hitman,, she is on a trailer at mo on her way to z tech , where ryan is going to look and see whats wrong will keep posted, any clues guys?? ps would like to thank ryan for all his hard work to get her done intime for jae, ,but its not looking good at mo,,
I think I may have seen you (assuming you were there around 7pm), but I saw you late and I was in the outside lane so couldn't stop. :(
Hope it doesn't turn out to be too serious. :nono:
was you in red zed or the silver one saw to go past, and couple of twats in a corsa , who found it amusing, when i get it fixed ill still get home before them , ,w.....kers. . np bud ,help was on its way , and yes it was 7pm,
she will be back on road soon i hope ,, depends on whats wrong??? :cry: :cry: :cry: :cry:
*****x sorry to hear that paul,im sure what ever happened it will rectified Asap
in time for jae
fingers crossed. .forgot to say thanks to you too , i no you two worked your nuts off to get this done in time much appriciated ,
I was in a red zed with dark windows so you probably couldn't see the kayak in the car with me! My sideways vision was a bit restricted, so rapid lane changing wasn't really possible. ;)
Hope you get it sorted asap Paul :(
Don't you hate it when your zed is sitting by the side of the rode and some fooker stops to take pics... :tongue:
ok guys its terminal . engine fookin siezed,,, ryan will be on later to explain ,,, no jae , for me!!
Sh*t, really sorry to hear Paul :( these things always happen at worst times
Not good mate, if it was mine id torch it calim the insurance and start again. But then me and my car arnt best of mates at the mo.
yep especially as i spent most of this year of the road saving for new turbos etc etc,, now this , im fed up proper ,, i tell thee, ive only bin to 3 meets ?? was so looking forward to jae, , new i should of bought a supra, ,, joke!! no pisstake intended to any supra owners,, especially as there engine works :cry:
Buying the zed was the worse decision ive made after getting married LOL. Mind you both ruin you financially and give you a headache.
FFS, how has the engine seized?????
Its only just come outta the garage?
Rich
yep but the zed always put a smile on me face, ,except for those drunken nights ,, ie the missues , lol too much detail again , dolt,. only trouble is to give up now would be silly,, only thing left is the auto box,, nuts shouldnt of said that,, or the diff or prop shaft, or loom ,, hmmmm , ,i no it will be worth it in the end ,there is light at the end of the tunnel , just hope its not a train coming the other way
to chunk , i have no idea ryan did explain to me,, but it flew straight past me head, ill let him explain because i have no idea, ,
Gutted for you buddy, cant believe it :(
You can still come to JAE without the Z, i know it wont be the same, but dont miss the biggest show of the year matey!
i got to sleep on it rich i did have fun at japfest when mine was at home stuffed, but was missing out on it bieng there, i will keep every one posted., ,as to wether to go or not, the mrs is a bit fed up with zeds at mo, ,she just wants a sofa. so im in the dog house for next month or so , again~!!!
Paul, I'll be there Zedless mate, so you wont be alone!!
Well if im zedless i wont be going so fingers crossed. :(
Rich
:( When we got the car back it was quite obvoius she was seized solid so empted out the oil to find nearly 5 litres of coolant followed by 4 litres of oil which hit the oil pan, this can only be down to cracked block or head gasket failure across a water/oil way. Until we can get the engine stripped down we will not be able to find out what is salvageable and if it was the block or the heads , both will need pressure testing etc to find the culprit.
The oil on the floor is where there has been such a build up of pressure in the crankcase because of the water it took out the rear main seal :(
Shame as she ran really sweet with the new tubs that we fitted and back on all 6 cylinders
just to note the work we carried out for Paul was Turbo replacement, big end bearing examination and change, seal replacement on all seals, the engine was never stripped or taken apart.
Ryan
see there you go,,, now i understand,,. cheers ryan,will keep you guys posted on how soon she will be out ,but its not for a few weeks at least, but on the plus side at least i know engine will be even sweeter when she comes out,and after i run her in , bring on the boost controller, stuff the sofa!!!!!!!!!, oh shit i shouldnt of said that,, i will not let this beat me ive come too far and spent so little, £2700,, :headvswal i wanted a zed well i got one, :headvswal and she will be alive agiain soon enough , :bow: :bow: goodnight!!
