front tension rods
Hi to all. have a bit of a teckie question....I am wondering the difference ( if any ) would changing the front tension rods on my uk tt make to these tien ones i've come across.....I already have tein suspension on the car and have been told the oem ones already on the car are knackered ( the bush anyway) and would this make a worth while change... I think they are £199 to get the new teins...
Do you realy need teins?
not really, just open to suggestions..is that what you have on yours dave..just tryin to do everything as well as possible, spent a fortune so far!!!
theres a bit of conflict on bushes i have poly tension arm bushes and find them spot on,i dont think it is essential to use tein tension arm bushes as you wont notice any differance over tein/poly-energy or OEM just get new ones should be fine
OEM have probably been on your car since it was built so they cant be that bad.
my mechanic just said they were shagged and need changin , so as i thought i spent 1k on the tein suspension, got the calipers all rebuilt and re coated in teflon, and changed my discs from oem to dba's 4000's and porterfields and have had all the arms all resprayed to new standards, it makes sort of since to finish it all off, if you get me drift!!
