New Koni shox pics and info
It turns out that the rears are actually adjustable rate too - they just have to be removed to adjust them...
I think that this is not a problem cos once you have the desired rate, you just adjust the fronts to change the oversteer/understeer characteristics of the car.
Any questions??? Ask away....
CheerZ,
Andy
muwhahahahahahaha your all suckers....
hang on i also got some smile.gif THEY DO LOOK VERY GOOD I CANT WAIT FOR MINE TO GO ON
i actualyl have a proper question
why do you only have one white adgustable nob in the image ?? and can you adjust the reas form the top of the shock? and are they click adjustable
The rears have to be removed to adjust the damping rate - this is because you need to fully compress them to engage the adjuster....
The fronts are not click adjustable but with a very small amount of care you'll be able to get them the same. You only get one adjuster because....well.... can you get one hand on the top of each shock at the same time???? NO I didn't think you could tongue.gif
CheerZ,
Andy
Once mine are a little more worn i.e. the back ones which have only just been replaced, I'd be up for a set of them.
you stupid arsehole.
thats all i wanted to know.
i actually wondered if they would be left on, so was a valid question.
what are those white tingys is ther enot a guage we can make to go on each shock to tell the amount of turn. ie can you how many degrees can you turn the shock adjuster around
Well hope you all realize that you will need a set of new rubber boots to go over them,because your old ones will be split frown.gif.Had a quote from NELSON £83.20 mad.gif
How mucchhh? FFS!
I know mate where do they get their prices from frown.gif.
Yeah the instructions do say you need to swap the boots and replace if knackered.... Shit happens though! I have had a little play with these on the damping front and they are simply EXCELLENT!!! biggrin.gif
CheerZ,
Andy
Oh and btw warren - those white discs seem to be dust protectors for the top of the front shox..... They slide onto the damper shaft and sit on top....
CheerZ,
Andy
