NA Engine temperature
Hi everyone, if there is anyone out there that has an NA with an aftermarker temperature guage fitted can you tell me what temperature you car runs at, mine goes to 150 fahrenheit which is about 65 celsius and I thought it should be a little more than that so just wanted to check with you guys, cheers, Richard.
where's your gauge fitted mate? mine reads that, but I know the reading is wrong. Don't mind too much as it's consistant so I can tell when it's running hotter
Gauge is fitted on the A pillar, I know the TT runs at about 85 celsius and thought the NA was about the same, any other NA guys getting this sort of reading?
I would presume that Jaffa was asking where abouts the Gauge sensor is fitted, rather than the gauge itself.
ย
My TT runs at around the 75-80 mark, I would of presumed the NA would run the same or slightly cooler, but 65 does seem a little too cool.
mine ran wi the sensor in the top rad hose and normal was about 80-90 degrees - 92 was absolute top running
ย
:p thats not what he said though :p sensor is in the top rad pipe
top rad hose and Never gets above 155F, hope it helps
ย
ย
ย
ย
Pete
Seems like thats normal then, been out for a thrash tonight and 155F was where it stayed, cheers guys.
DOH, i did mean the sensor. sounds right then. mine reads about 145F usually, but on a consult it's around 75 degrees. I think they under read as the hard pipe isn't earthed.
