Is there a bearing between input shaft & crankshaft???
Hi, does anyone know if there is supposed to be a bearing between the input shaft on a manual box & the crank because it looks like the input shaft just sits into the crank with no bearing which I find rather strange. My car is making a a squealing noise which I put down to the thrust bearing but now I've found that there is quite a bit of play in the input shaft, is this normal? I'm confused by it all!!!!
Any advice would be welcome.
Cheers,
Shaun
More than likely it will be you Pilot Bushing - It is made of bronze and is soft as hell - The Garage that did my last Tranny work made a fucking totaly mess of mine - And it was making some sound !!! check that if i were you.
Z ya
Nico91TT
