J spec spoiler brake light bulbs
anyone know where I can get these from ?
I got 3 from a local motor factor (for over a fiver :shock: ) but the actual glass bulb size was too big to fit back into the light lens.
Paul
Paul, got them from local nissan dealer, part # 26261-30P00
-Andrew
-Andrew
Just rang Nissan Main Stealer £2.03 ea +VAT :shock: and ordered 3
Can anyone confirm what wattage these bulbs are please
the ones I took out are 21w, on searching the furums on here it looks like 26261-30P00 are only 13w :confused:
Hi,
You can find similar once at B&Q (Yes it is true) or other garden centres, as there is a 15W version of the same bulb that is used in some garden lights. You would not be able to see any difference between 13W and 15W, so they should work OK. Have seen them myself at B&Q in Ireland so should be available in UK.
I use 501's in mine, they fit and despite being 10W it looks fine.
and they cost fook all each too.
501's ?
Got mine last week from motorworld. Part number RW501 12v 5w capless.
Price £1.99 for 2 .Ignore the wattage rating. They are the same brightness as the original nissan ones that I took out.
Hope this helps....
i got a complete reaer spoiler jap light assembly here good condition with bulbs, your welcome to it.. pm me your address and its yours.
501's ?
Yes, small capless jobbies, all normal cars use them as sidelights. Zeds use them as side repeater bulbs.
