EngineManagement
Could you guys please advise on the best management systems there are for the 300zx?
I'm planning to use X2 GT2530 blowers, 740cc injectors, and a single twin in/outlet FMIC and 3" bore pipe work and exhaust system (where 3" will fit and as big as poss else where), I'm looking for a minimum 600HP
I want to use a standalone management system, the Apexi Power FC would have been perfect for me but it apears that you can't get 1 for the 300zx :headvswal (unless anyone knows any different) so could you guys please give me examples of systems that are similar to that. Hard wiring systems like the Link ECU in not going to be a problem.
I have seen the Link and Motech systems and like the idea for attaching a PC to them for mapping etc.
Thanks in advance.
Chris.
Try thor, they do the LINK, which is a standalone which uses the existing harness I believe. You take out the standard ECU and put the LINK in and its totally reprogrammable.
There is also DTA http://www.dtafast.co.uk/
If you're using emerald, I'm going to be making a conversion harness to fit it to the Z32 soonish. Already looking at getting new CAs trigger disks made up.
