H pipe
Hello,
I want to change my exhaust by one I will do myself. But my question is do I need to keep that H (or X) pipe ? or can I do two line with no communication ?
What is the H pipe for?
Thanks a lot
i don't have one and seems fine to me, affraid thats as mechanical as i can get.
Most (all?) aftermarket exhausts don't have the X pipe. It appears to reduce noise slightly by evening out the pulses from each bank of cylinders (L & R) within the system. With an unconnected twin pipe exhaust, this energy transfer doesn't happen. When I changed from OEM standard with X-pipe to Mongoose without X-pipe, I noticed a droning noise peaking around 2,000 rpm which wasn't there before.
I saw something on the Aus site ages back which suggested that the X was a more efficient solution than the H. However, one of the more popular systems, the Mongoose, has no link at all as previously stated. Unless you're searching for some extreme perfection I don't expect it will make much difference.
i believe the h pipe is to help with low down torque and that the pulses from each bank help pull the exhaust air from the other bank, and the X pipe is the same principle but does a better job .
You want one of these ;)
Call to order :nana2:
Chris out of interest how much are they and what size?
Built to spec so price and size all change contact for more info.
I can have one built for me stainless plus test pipe for 440€ fit on my car.
Who have better price?
pulse tuning dont work on turbo cars, fooking great turbo in the way!
