engine oil
my car is really smokey at the min think it may be the oil.
i'm running 10-40 i believe is this correct?
Worms - Can - You - opened!!!! ;)
IMO 10-40 should be ok.
ok, brill must be something else then.
kinda hoping it was something simple causing the smoking problem.
Try replacing the PVC pipes and valves, MJP in the traders area can get them for you.
ok thanks, my mechanic said that it could be my turbos or rings or something in the engine, if this is the case as a short term solution i have been advised to put thicker oil in.
is this true? if it is what should i use?
As a short term approach I'd suggest replacing the PCV's - it's easy and won't take much longer than changing the oil.
agree with andy. whens it smoking? all the time/when accelerating/on overrun, hot/cold?
