300 T/t Engine Probs
Can Anybody Point Me In The Right Direction,my 3oo Blew A Hole In The Right Hose Jst Below Turbos, Stripped Out Replaced Hose And Rebuilt,now Got Loads Of Pressure Thru Ma Water System Wen Tryn To Bleed It.need Help!!!
if you have pressure in your cooling system i would guess your head gasket is blown also check for white sludge around the oil cap and oily deposits in the water,also white smoke is a give away and with the rad cap off when you rev the engine it will push the water out of the system
Excess pressure in the cooling system usually points to a head gasket problem. :headvswal Welcome to the forum , if its not that i,m sure someone will point you in the right direction :hyper:
THANKS THIS SEEMS TO BE THE SAME AS EVERYBODYS TELLIN ME APART FE SOME NUTTERS SAYN THE ENGINE NEEDS REPLACED, MANY THANKS, THE 300s NOW GETTIN BTR IN HOSPITAL !!!
