- Replies 30
- Views 1.2k
- Created
- Last Reply
SuffolkZX 5 posts
takemetothepub 3 posts
craig-s 2 posts
turbopsychosis 1 post
Hi guys,
Spent most of today replacing the front discs and pads on the zed exactly as on the tt.net website and got through it all okay But when i tried the car to test them the pedal just seems to go right to the floor while only applying minimal braking. if you pump it a few times it gives more pressure but just drops away again if you dont touch the pedal for a bit.
pretty sure i didnt get any air in but could be wrong and positive the master cylinder is okay because they worked fine before hand but just squeaked cause the pads were shot.
Does it sound like it needs bleeding? will i have to do this from the caliper or the abs unit?
Any ideas ?
any help appreciated!
Nick
