So engine tune session today and managed to get the engine purring if not with a few issues along the way.
First issue was we found a vac pipe leak after tracing the ecu vac sensor pipe to a Y splitter that had its own split.
next we found the CAN wide bands didnt come online and that was again just a loose cable.
Lastly was a much bigger but fixable issue and after all the time splitting and rebuilding this engine i couldn't believe i done.
Can anyone spot the rookie mistake that i freely admit to doing which led to having to stop the session :
JaiKai ·
just reading this faq on the "boost jets" in the faq section
if you put these restrictors in the line for the pressure to build up higher would this not cause more turbo lag?
also are the 300zx turbos sequential or not?
thanks
