Not too bad to be honest, a little pain in the arse maybe. You have to remove the air con box inside the car to get to the bolt at the top holding the loom to the hulk head.
cheerz, mickey
There was no bolt on mine - but it was hells own job to get the giant ECU connector through the bulkhead (actually, I smashed one doing it!) - removing the a/c box is the way to go there I think..
Be aware though that you'll be ordering a LHD one, which means you'll have a ton of excess in the engine bay unless you start cutting chunks out and splicing the loom back together.. The excess is because the LHD loom is identical except for the fact that it runs along the firewall to the other side of the car - whereas the RHD loom goes straight through into the cabin. So you end up having to tuck about two feet of loom down by the battery.
Other than that, it fits fine.
See here for a semi step-by-step - http://www.mindserv.co.uk/loom_replacement.shtml
no air con on mine , as its been removed anyway !! But any ideas on how much a RHD one is ??? or where i can get one ?? Mike mjp perhaps ??
Mike is definitely your best bet, unless you can get one direct from Japan somehow..
Expect a big price tag, though :(
I just put the LHD loom in mine no probs with it as of yet
there not too bad £300 if i remember correctly
Karlos, although you have had the air con compressor removed, I think youll find you still have the box behind the dash :)
Baggins - I hope so - that's what you quoted me ;)
dammit LOl no probs , il leave it till its completely nakered then i think. i mainly asked for paulstevo as him loom has been hacked to death and i think its causing him problems. Cheersd for advice though Hugh.
engine connectors from durite 01255 555200 ask for catalogue
2 pin ie temp sensor, injectors £2
3 pin ie tps £4
4 pin ie cas/afm £6
wiring loom £600-800 and 3 months from japan
your choice but know which i did lol
