Code 53
Hi guys, this morning I was in saftey boost, did ECU check and got Code 53. Found this on a search :-
(the list from TT's of dallas has got code 53 as the right side O2 sensor.)
Anyone know where this is located so I can check wiring ect. ?
Any suggestions
Paul
02 sensors are located on the exhaust straight after the turbo's . Find the turbo and follow if back and u will see the o2 sensor with a wire coming off.
Just as a matter of interest (as a MAY be able to get them cheap) can a Z31 lambda sensor be used on the Z32 ?
not sure about that mate but they only cost $61 Dollars each with Courtesy.
