Adapting Steering boss..What pin is horn?
I have to bodge a steering wheel adaptor/boss to fit my TT.
Does anyone know what pin is the horn on?
left/ middle/ right?
also...
as i have eliminator fitted can i just remove the hicas 3pin plug and cut a slot in the boss for the turn indicator peg to go through?
Any FAQ's on this?...ive searched but not found :(
This is my boss and steering column piccys:-
this is the 1 mate. these 2 are linked.
cheerz, mickey
You need to cut a slot in the adaptor body to take the 3pin boss,that way the horn is connected without using the slip-ring[that's no use anyway!]
and also the indicator cancel will work!-does this make any sense?? :wack: :D
Thanks very much for your time peeps :bow: Much appreciated :duffer:
Bit of this :smash:
and a bit of that :smash:
should sort it then... :nana2:
