protoj · Tuesday at 18:48 2 days
Check link below for pics of my new brembos, soon to be fitted to me zx. They have done only 1000 miles are from a 1999 R33 VSpec. Should be able to stop soon
JeffTT - (ZX Craftsman), Hope ur ready !!!
http://www.300zx.co.uk/rides/300zxtt/brembo-1.jpg
http://www.300zx.co.uk/rides/300zxtt/brembo-2.jpg
http://www.300zx.co.uk/rides/300zxtt/brembo-3.jpg
CheerZ
Shabir
