questuion about new turbos after fitted
got my Zed back after having new new hybrid turbos fitted 2day
car is running sweet and everything
anyway
took it for a MOT and the bloke noticed some oil leaking from the passenger turbo (on the floor, there was a small patch)
phoned the company up and he said it was normal for a bit of oil to be on the floor, he said it was prob just what was on the turbo, they prime them with no pipes on??
bit lost, the work is garrented so thats not a prob, any every had this before??
car failed on a blocked washer jet FFS!!!! :-(
any ideas? he told me to run them in for 250 miles which i thought is not enough and get a oil change at 250 miles which is fair enough
what u guys think?
Any kind of oil leak is not a good thing especially from a tub. Yes you do have to prime them with oil so it could be that but those tubs get so hot it would probably burn it off before it driped. Does not sound good if there was a patch of oil on the floor. Keep a close eye on it and if it is still the same after a day then take it back!
oil feed pipes might be leaking from the bango at best passenger side is slightly easier to access hope all is ok
id deffo take it back too mate !! last thing u want is oil starvation on a new set of tubs !!
ok guys, ill check it 2day and if it is still leaking then its going straight back :(
pissed off as i want the car done ASAP!! :(
FFS, some garages should be shot! take it back. there should be no leaks, esp if its enough to actually drip on the floor!!!!
Hope it gets sorted....
Cough...Cough......Nudge...Nudge.....
Boost Leak Detector
its still leaking so itsgoing straight back
not happy about it at all!! :-(
Mark, still waiting on a cheque for the boost leak detector.
Vijay
Surely if the turbo's are changed, as a matter of course the engine oil and filter should be changed irrespective of when it was last changed, small price to pay as contaminated oil does damage to bearings etc,
Cheers John Crisp
Oopsie then change it again after 250 miles, new turbo's=new oil/filter to me.
Cheers John Crisp
sorry vijay ill get it to you asap
just moved house and with the car and everything its all abit tits up at the mo
