Electric fan/fan noise
My Jap import is into is second day on the road. Been really warm down here in South wales today, and my car is running fine, temp seems normal etc.
BUT is sounds like it has an electric fan running all the time. Its been in the garage for 2 house, and i started it again, and the noist was still there ?
Is the an elec fan as well as the viscous belt driven one?
The electric fan will run constantly if the ECU temp sensor reading is not being received by the ECU. Make sure that the connection is good (it's the larger one on the top water pipe IIRC)
Steve :)
'93 UK TT Manual
cheers buddy, i will look tomorrow morning.
So, there is an electric fan also then ????????? Obviously for extra cooling, is that due to the excessive under bonnet temps ??????
Is that the one on the solid pipe next tp the engine temp sender???
Yes, that is the one.
ok, took it off and blew it put it back on, still fan is on, anything else i should do other than blow ??
Dai
Erm, yeah, replacing it would be good. They aren't much from a Nissan Main Stealer. Are the connections corroded?
Dai
Usually takes a little more than a "blow" when you remove the connector a fine screwdriver to scrape any crud off the ends is helpful and better still electrical connector cleaner is good.
The fan also comes on with other faults within the engine so an ECU test is probably best to be certain and only takes 10mins, this will pinpoint any errors within engine bay for yer.
smithy
Cheers Smithy, had a service and consult with ztech last week and no faults were found??
Certainly try scraping/cleaning the inside of the connector. It could also be a bad connection in the cable - try running the engine and wiggling the wire/connector to see if the fan switches off at all. If it does, you've isolated the problem...
Steve :)
'93 UK TT Manual
thanks guys.
will try those things.
Unplugged it and it stayed on, though i assume thats a 'fail safe' thing??
Took plug off, cleaned connectors, put plug back on -
result - no more aux fan on, and idle back down to its normal level !!
Thanks Board members!
and if its a tt you'll have full boost back and better fuel consumption!
Cool !! Seemed to be boosting fine - 0.6 kg/cm3 but it's defo idling better.
