Pulling left!!
My car is pulling to left quite heavily. Im at chichester in w.sussex, anybody recommend a good 4 wheel steering alignment garage around the south coast that can do the business.
This happened to me, and no wheel allignment could fix it.
I think it ended up being the tyre. Also check every single bolt on the crossmember, steering and suspention is torqued up correctly.
Can a nissan dealer do 4 wheel tracking or does it have to be a specialist??
depends if they have 4 wheel alignment gear!
...take the front wheels off and make sure the brakes aren't binding - and are in good condition - clean, greased and free-moving. Then check for un-even tyre wear - any signs and it could be (front wheel) tracking needing adjusting.
A decent tyre shop will adjust it to it's maximum limits to counter wear in the (I think) top links. Mines been adjusted as described and stll pulls to the left a little - but after 5 years you get used to it. Other interesting thing to note is that when adjusted the tyre wear is perfect, no scrubbed edges.
Good luck
...dont forget, the TT engine is about 12 stone heavier than a NA engine so it'll wear front suspension componentry quicker - and I'd imagine that the shorter wheel-base also adds extra weight (leverage) compared to a 2+2.
Also check the bushes- the rack bushes went on mine and the main thing I noticed was pulling to the left, but it was also very vague when trying to steer straight.
Mark
