identify these?
I just had my clutch replaced and noticed a wire trailing under the car near the middle/front of the gearbox area, I unplugged it from the smaller connector of these 2 - the other end is missing and has no plug attached so Im not sure where it goes. The larger of the 2 connectors has nothing plugged into it? Any ideas people? car seems to drive fine?
There are wires which come from teh gearbox.
ย
On the side of it where the gearbox fluid comes out into the oil cooling pipes. One of the banjo bolts has a plug on it.
any idea on what they're for?
one wire has been lost/broken so I need a new one of them . . . .
ย
just not sure what they do
think I sussed it
one is a reverse lamp connector as my reversing lamps have now failed.
second one is poss a neutral switch? What would this be for on a manual?
ย
do you think its part of the loom that would plug onto an auto box if fitted?
ย
One is the reverse lamps and the other is the neutral switch on the gearbox. and yes the manual has the neutral switch.
so, if its not connected what happens - car seems fine without it being plugged into anything?
