The breather kit (fitting-Q)
Evening all,
Are there any fitting diagrams or instructions with the kit or are we just suppose to know where it goes! Because i've been told the connections & bits must be 100% sealed. As i & there must be a few others that arn't that knowledgeable on pipes & stuff.
As most of us saw warrens at the rolling road day, the new mods that have been carried out since a mistake in manufacure on the pipwork as i've read in the updates!!!
Are we to take anything else into consideration? Positioning etc.
And any chance of chrome plastic, instead of red & black plastic valves?
Warren have you sorted yours, (cleaned um)
& how are they now?
And any chance of a rough arrival date - as the plenums going of for a sortin'.
Cheers harve
Yes you do get instructions m8. Not that they're very easy to follow mind you.... wink.gif The problem with the kit originally was that the tubing supplied was too hard and too tight on the connections. Warren's was the first kit to have the new pipe but there have been problems since then sourcing enough.... All I would recommend buying is about 16 jubilee clips - about 1" should be about right, maybe slightly bigger... The job is much easier if you have seen one fitted already btw wink.gif
CheerZ,
Andy
