Speedo wiring (removing converter)
I have removed the converter from my 90 tt, and i have the speedo cluster removed. 1 wire was cutfor some sort of feed, so i reconnected it from the loom into the speedo. However I have a black wire with silver dashes on it, that goes from the harness to the speedo, but has a green wire teed into it. This green wire disapperas off down under the right side of the dash. Any ideas where its going, and what i do with it. Thanks.
Car returned code 55 on an ecu diagnostic, so all seems fine there, anyone any ideas??? :headvswal
Somebody must have a diagram for wiring up a speedo convertor. And I'd also like a scan of it up on my site ....
I think its a new cluster i need. Previously with the speed converter fitted, if you tapped the top of the dash , the speedo worked, then if you hit a bump, it would drop to 0. Now i have removed the converter and it still works with a tap on the dash, si im thinking it must be the cluster.
I assume you disassembled the cluster?? Is it easy....
