As my controller is at the menders i'm running 1mmm boost jets but i've noticed after between 1/2 and 1 hour it jumps into safety boost regular as clockwork now and won't change unless i stop the car then re-start it????
Could it be running too hot problems with fuel or something???
areid@empiredesign.co.uk
have you checked for code 34 (det sensor) on a ecu check, maybe starting to mess about.
have you changed your fuel recently, do you use Optimax??
you could be geniunely detting, how much boost are you running with the jets?
You can't say fairer than that.............oh, I just said it! Mark is a top man.
Cheers James :o
