Safety boost
As my controller is at the menders i'm running 1mmm boost jets but i've noticed after between 1/2 and 1 hour it jumps into safety boost regular as clockwork now and won't change unless i stop the car then re-start it????
Could it be running too hot problems with fuel or something???
areid@empiredesign.co.uk
have you checked for code 34 (det sensor) on a ecu check, maybe starting to mess about.
have you changed your fuel recently, do you use Optimax??
Alex why don't you pop over to Putney, I do free consult checks :)
You can't say fairer than that.............oh, I just said it! Mark is a top man.
you could be geniunely detting, how much boost are you running with the jets?
Cheers James :o
