Clock removal
How hard is it to remove the clocks please...............
:bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
pretty easy but if you wish to remove the speedo pointer ie to put mph dial on import car you will need a special tool and also make note of where it was pointing before you took it off
Thanks lads. I have removed them and yes it was pretty easy. The speedo and rev housing. I am going to attempt to make my own so when they are done keep your eyes open and I will post some pix.
Be careful though. Remove the little black needle stop before removing the actual needle. It has a preload and its rest possition isnt nessacerally (spelling!!) on the Zero. After removing the stop, the needle will swing further down the dail. That is now where you need to make your mark. I didnt realise this and took me hours to get the needles in the right positions!
Andrew :D
