May 28, 200520 yr Been in and drove 300zx twin turbo fell in love not a petrol head just love the style and rush want one for myself now don't want to be baffled with techinical stuff just want to know what look for got about £3-£5k to spend help
May 28, 200520 yr welcome mate ... you can check out some buyers guides here http://www.300zx.org.uk/tech_20.htm Best thing you can do is subscribe .... all the best, Chris
May 29, 200520 yr Hi Lev got mine nearly a year now a 93 TT uk spec with 55k on the clock and i love it! This wuz the 1st one i looked at and was a minter i was v'lucky. Ive had no probs apart from a bad idle but thats cured now! Try and get the best you can afford mine was standard with full service history and had a AA report done. Hope you buy if you get the right one u'll not regret it! Ps thats a great thread Chris put you on it solved my idle problems 1st crack!
May 29, 200520 yr 300zx What was up wit the idle on your car? Mine also idle's poorly? How did you cure it? Karl
May 29, 200520 yr Hi,it just would not idle steady steady at all! I cleaned the throttle boddies and it was fine. If you go onto the thread above u'll find out how to do it and a lot more it's a great site! David
May 29, 200520 yr Hi David Thats what many people have told me to do. I will have a go at this tommorow. Mine idles 'lumpy' when hot, almost stalls sometimes. Also, when you sometimes stop at a junction it will stall, always starts fine though. If the aircon is on, then all the idling problems go away. Thanks Karl
May 29, 200520 yr Welcome lev yashin, 300zx.co.uk buyers guide here : http://www.300zx.co.uk/tech/BuyingZ.htm Description of Model variations here : http://www.300zx.org.uk/model_variations.htm Hi David Thats what many people have told me to do. I will have a go at this tommorow. Mine idles 'lumpy' when hot, almost stalls sometimes. Also, when you sometimes stop at a junction it will stall, always starts fine though. If the aircon is on, then all the idling problems go away. Thanks Karl Karl, Have you checked TPS (throttle position sensor) reading. Should be 0.44v (+/- 0.2) ?
May 29, 200520 yr Yep thats the same as mine but the air con only lifts the revs not solves the problem! It worked for me just hope it works for you! Also try cleaning the coolant temp sensor may also help.. Once i cleaned the throttle boddies i sprayed carb cleaner through them while the engine was running but make sure not to have anything on top of the engine in case it falls and snaps a belt! Ps before you do all that disconnect the battery and then reconnect it after about half an hour as this will reset the ECU! Happey cleaning David
May 29, 200520 yr Ok guys Well now im going to show my ignorence! I will happily take this whole engine to bits and put it back together again, respray the entire car etc etc, as I have with many other cars, but can someone explain quickly where the TPS (throttle position sensor) is. im guessing (of the top of my head) its the sensor on the end of the throttle bar? now I look daft!
May 29, 200520 yr Little black box, mounted on side of block near throttlebody. Check its voltage with multimeter. Use earthing point on Battery, and positive probe on middle wire on the TPS connector. A reading of 0.44v +/2 0.02v is expected. It can be adjusted by undoing the screws and changing its angle. If you have general idle problems, then best to check this guide : http://home.swipnet.se/e-solutions/IdleTech.html
May 29, 200520 yr Nice one Legrath, Up early in the morning and I wont shut the bonnet untill it idles perfectly!! Thanks for your help! Karl
