Preparing for 60K Service
well i was back in the driving seat for a whole one day and my water pump failed so the zed is again off the road. it's due its 60K service soon so i think im gonna have a go at it, i want to do as much on the car myself as i can so i can learn more! had a look at the 60K maintenance guide on ttzd.com and just want to check with you guys if there is anything else i should do while im at it:
Spark Plugs
Fuel Filter
Timing Belt
Alternator Belt
A/C Belt
Power Steering Belt
Auto-Tensioner
Thermostat
Water Outlet Hoses (2 req'd)
Water Pump
Water Pump Gasket
Cam Seals (4 req'd)
Main Seal
Intake Cam Sprocket O-rings (2 req'd)
Intake Cam Sprocket Springs (2 req'd)
Main Crank Sprocket
Crank Rear Spacer
i did an oil and filter change very recently myself so no need for those.
other things to do at the same time (because its easier and might as wel while its off the road) cos they WILL be done sooner or later:
Lightweight Pulley (need different belts)
Plenum water bypass (no idea what i need)
Paint throttle cable and cam covers
SS rad pipes
SS intake pipes
NA power steering pump and hicas removal
Tranmission fluid change
have i forgotten missed anything? will probably start this mamoth task in 2-3 weeks. any of the leics guys fancy getting their hands oily? lots of tea, sandwiches and biscuits!
Yaseen
Spark Plugs
Fuel Filter
Timing Belt
Alternator Belt
A/C Belt
Power Steering Belt
Auto-Tensioner
Thermostat
Water Pump
Water Pump Gasket
Cam Seals (4 req'd)
Main Seal
Main Crank Sprocket
Crank Rear Spacer
SS rad pipes
SS intake pipes
Yaseen
if your doing the main seal then removal of gearbox is required and unless its leaking i wouldnt bother again main cam sprocket unless damaged is not needed!
intake cam springs you can get in the 60k service kit you may aswell fit,but are not major unless you have leaks from the camshafts/covers
water pump gasket is a case of useing a bead of sealent,again when replacing the 2 small water inlet and outlet hoses check the actual metal pipes for corosion as over years they become thin brittle and could crack etc
thanks greg
scratch the cam sprocket and water pump gasket then.
iv got traces of oil at the back end of the sump (between engine and 'box) so im guessing main seal does need replacing. but if its a gearbox out job i'll leave it for a garage to do that later.
do you mean the 2 pipes that sit behind the fan? one has the two sensors on it? i'll make sure i check them
yaseen, greg is talking about two metal pipes behind the two rubber water hoses you are goint to replace. They only become visible when you take the rubber ones off. As greg saysd they are usually rusty as a minimum, or badly corroded in the worst case. When you get them off give them a good wire brushing, and if you have time to let them dry properly a couating with some zinc based paint. And dont forget a set of long reach hex keys (allen Keys) dont buy the ones with the "wobble" fitting on the end, as I have had two so far brak the "wobble" and leavit it in the head of the bolt you are trying to undo, not good. These are needed for the bolts that hold on the upper and lower water pipes. Good luck :)
Spark Plugs
Fuel Filter
Timing Belt
Alternator Belt
A/C Belt
Power Steering Belt
Auto-Tensioner
Thermostat
Water Pump
Water Pump Gasket
Cam Seals (4 req'd)
Main Seal
Main Crank Sprocket
Crank Rear Spacer
SS rad pipes
SS intake pipes
Yaseen
The phrase "Biting off more than you can chew" springs to mind!!!! :rofl: :rofl: :rofl:
Hmm, I did the oil change ok myself, might have a pop at a 60k service!!!!! :rofl: :rofl:
Sorry yas couldnt resist it!!!
Seriously though Yas, make sure you know what your letting yourself in for, i did my water pump 2 years ago, but wasnt brave enough to swap out the cambelt. Im summoning up the courage now to do it this summer.
Make no mistake, to a novice mechanic it is a lot of work.
And good luck, by god you'll need it!!!! ;)
thanks for volunteering your services! lol nobhead :slap:
seriously if you can even spare a couple of hours when i'm doing it, i'td be a huge favour.
im not scared of doing it, i just know cos its my first time itl take me ages, dnt care how long it takes tho, i like doing stuff like this.
5-6 hours for a 60k service add 3 days for your 1st time PMSL
Gotta respect this mate .. really. I can do most bits and bobs but a 60k service (cambelt)
Gotta respect this mate .. really. I can do most bits and bobs but a 60k service (cambelt) gives me the shivers ..
Hope you get on OK .. how about a FAQ as well to see how you get on .. would be interesting.
Good luck
Chris
double post doh
Not my fault .. LOL .. I blame Mike ... his coat got caught in the server LOL .. sorry
oh no the sheep coat is back LOL
don't really mind taking 3 or even 4 days to do it, as long as i do it myself. i enjoy working on the car.
