protoj · Tuesday at 18:48 1 day
From advise on this forum that i am very greatful of. i have discovered my speed sensor & ecu coolant sensor are shagged, would anybody know where i can get replacements from.
I'm assuming they aren't that hard to change!
Thanking ya well in advance
