Indicator problem
My bloody right front indicator has stopped working, wont flash when turnong, wont flash with alarm, yet works fine with hazzard lights..
any ideas please ?
any ideas please ?
yeah.....try this..... :smash:
As there is no separate wiring circuit for the Hazard and Turn Signal, then I'd be looking for a duff earth connection on the right hand side. THUS- It's getting it's return earth path through the left hand side when the hazard is switched on.
cheers dave, that would make sense i guess, is it just a case of earthing the holder then ?
As a temporary/test you could just run a wire to earth from the lamp holder and see what happends. Then if that proves to work, then check out the proper earth connection and see whats up with it.
Sorry I can't be of anymore help, but this is a tricky one, as there isn't really much that could go wrong with it.
I'm assuming your right hand rear and side repeater are working OK?
yes mate, they are working fine, all be it fast due to the front not working.
thanks for your help, will try that
