- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi guys
Ive noticed, and the car has done this for about 3yrs now, but now its becoming realy anoying! that if the air con is off, and you drive towards say a round about, junction or red light, when the clutch is pressed and the revs drop, the idle goes to approx 400-500, shakes and the engine cuts out. Same thing happens if say you drive in 4/5th gear at 40+ and you pressed the clutch and let the engine idle, it will stall. it almost seems as if the revs drop to quick? At standstill, you can rev the car, right to the limit in fact and it never stalls, the revs do drop almost to 500 but the engine does keep going (just). normally, the engine idls fine. Ive cleaned the pipes, sensors and throttles, but it has made no difference. I once did a ECU check and this showed nothing either? Anyone else had this problem? Solved it?
Many Thanks
Karl
