Engine Assembly time.
Managed to get the heads back on, all the lifters and cams torqued down again, then fitted the cam gears and went to do the belt.
Not as easy as i remember it a few years ago so had dificulty getting the marks to line up with the crank pulley at the bottom.
I'm guessing the sprocket is slightly out so i'll try again tomorrow, but need to find some clamps to keep the top done.
By
JaiKai ·
Hello peebs,
Are you guys still coming down on the Friday or have you changed to Sat?
